Spektrum S1100 G2 1x100W AC Smart ChargerFree shipping on this item.
Features
The S1100 Smart AC Charger — from the new generation of Spektrum™ Smart electronics — brings today's most advanced and user-friendly charging technology to RC bashers, crawlers, and sport pilots of all skill levels.
With its 100W power, improved user interface, and ability to fast charge Smart batteries on the IC3® or IC5® integrated output port, the S1100 charger offers a versatile and hassle-free charging experience. You can charge virtually any RC battery with the S1100 charger. Use it with Smart batteries, and you'll be amazed by its incredible functionality and performance.
The S1100 Smart AC Charger makes battery charging the easiest it has ever been. Its Auto Charge feature recognizes your Smart battery's parameters, such as chemistry type and charge rate, and automatically begins safe, correct charging when the charge lead is connected. A clock on the charger's screen counts down the time until your Smart battery is fully charged and ready to use.
Balancing Smart batteries is just as simple. The S1100 charger will balance your Smart LiPo packs through the same single IC connection used for charging. No separate, confusing balance leads are required.
The S1100 Smart AC Charger's updated interface features fresh, intuitive menus, icons, and navigation tools. Its clear, easily understandable indicators of Smart battery history and performance provide the information you need to make the best decisions about your batteries when putting gear together for a day at the field or track.
USB input and output ports enable you to charge secondary devices and to update the charger's firmware, so you always have the latest version. The S1100 Smart AC Charger also includes an ON/OFF switch, cooling fan, detachable power cord, and sleek case with rubber grips that fits perfectly on your workbench and in your pit or field bag.
The Spektrum™ S1100 Smart AC Charger includes IC3® and IC5® output ports for charging your Smart batteries without adapters. Use the slider to select either the IC3® or IC5® port, and then charge your battery with up to 100W power. You can charge AND balance Smart batteries with one simple IC3® or IC5® connection — no separate balance lead is required.
To provide the easiest, most helpful, and most hassle-free charging experience, the S1100 AC charger includes an updated user interface with improved menus, icons, and navigation tools. A new Auto Charge feature recognizes Smart battery charging parameters as soon as you connect your pack and begins proper charging automatically for maximum safety, simplicity, and charging ease.
In real time, a clock on the S1100 AC charger's screen counts down the minutes until your Smart battery is fully charged and ready to be used.
The charger's sleek case fits perfectly on your workbench and in your pit or field bag. Its power cord is detachable for easy transport. Rubber grips help you hold the charger securely while connecting and removing batteries. USB input and output ports enable you to update charger firmware and charge secondary devices. Other features include a built-in ON/OFF power switch and a low-noise cooling fan.
