(1) Pair of Deans HB Male & Female Ultra High-Temperature Connectors for 10-12 Gauge Wire and up to 100 amps.
Deans HB High Temp Ultra Plug for 10-12 Gauge Wire. Like the original red Ultra Plug, the Deans' design eliminates the possibility of reverse polarity connections. Provides a secure connection for battery and motor connections on R/C vehicles. Deans plugs are small, easy to use, and work at loads up to 100 amps.Female ends are normally used on the battery packs.Male connectors are normally used on the chargers and esc's.Includes:(1) Female Connector(1) Male Connector(4) Pieces of 1/4" shrink wrap.
