Boca Bearings Marine Power Lightning Lube 100ml Spray Bottle. Lightning Lube Technology is specially designed to form a molecular bond with all moving metal parts within any application. Use it to reduce friction, improve performance, decrease wear and extend life. Lightning Lube can be used when installing new bearings and components or to preserve your existing bearings and components. It can be used as a pre-soak or by direct application. Can also be used as a fuel additive for RC engines: 2 pumps per gallon for regular or 3-4 pumps for high nitro content. Lubricate & Protect with the Lightning Lube line of Grease, Oils & Cleaners.
Easy application, Very thin and lightweight oil for minimal friction and reduced drag.
All-purpose bearing lubrication. Prolongs life of bearings or any moving parts.
