This high-quality foam tape is super sticky on one side. This can be used to help keep water out of hatches. But was originally made to cut down on vibration it's ideal for cushioning and sealing the gap on wing saddles. High Quality Adhesive backing, stick firmly with long-lasting stickiness, non-degumming. Soft and flexible enough to cut into different sizes and shapes for various use with scissors or blades. Please clean the surface before applying to prevent stickiness lost. Superior shock-absorbing, sound and heat insulation, dustproof, weatherproof, oil resistance, corrosion resistance, flame resistance, anti-slip and buffering. It withstands temperature from -50°C to 150°C. Length Otions:- 36 Inches (900mm)- 15 Feet (4500mm)Specs:Width: 0.5" (12.5mm)Thickness: 0.125"(3.17mm)**Sticky adhesive on one side only**
