ABC Cleaver Series 3 Blade Propeller, .75 Bar
We have these in sizes ranging from 1.5" (38mm) Diameter to 2.6" (66mm) Diameter These are .75 bar props, meaning they have more blade area than the .50 bar style ABC props.
NUMBERING SYSTEM XXXX-XX-XX(X) XXX For example a 1514-10-75(3) CLL breaks down like this. 1.5 is the diameter in inches. 1.4 Pitch Radio 10-RAKE ANGLE 75-BLADE AREA RATIO (3)-NUMBER OF BLADES CL-CLEAVER OR CP-CHOPPER L-LEFT ROTATION OR R-RIGHT ROTATION. NOTE: Shaft Size 3/16" (4.75mm) from 1514 to 1518.Shaft Size 1/4"(6.35mm)from 2514 and larger prop diameters.
