There are lots of things to consider when you decide to buy an Rc boat for the first time. First and foremost, you'll have to decide whether to go with Nitro or Electric. While a whole article can be done on this subject alone, the long and short of it is, Electric is a bit slower with less runtime, but easier to maintain, cleaner, not as loud, and much easier to run and keep running. While nitro is faster, has longer run times, but stall often. Even seasoned Rc boat racers have a hard time keeping them running. And they are also being restricted from use in lots of places because of high noise.
"Mono" Hulls
The Deep Vee design handles ruff & choppy water better then any of the other fast electric hull designs. They also turn great in both directions & are easy to setup. This make this type of hull perfect for the beginner.
Catamarans The catamaran design is a cross between a hydro and a deep vee. With the center tunnel, the hull has less drag then a deep vee, while also creating lift. The twin hull design makes it both faster then a deep vee, with the added benefit of better ruff water capabilities then a Hydro. The only draw back to the design is that a blow over in windy conditions is possible. They are somewhat harder to setup then a deep vee. At very high speeds the cat will be more stable then the mono because of the twin hulls. |
Outboard Tunnels Although it sports a twin style hull similar to a catamaran, that's where the similarities stop. Because of the low profile of the freeboard (hull sides), this boat will not take the waves very well. While faster then a traditional offshore catamaran its made for flat water only. Why Kyosho named the pictured boat a "Wave Master" we're still trying to figure out? |
Scale Hydros The Scale Hydro is the fastest of all the scale hulls. The only hull design faster is a rigger which doesn't resemble any full scale boats. A well designed, balanced and powered Hydro will run with only a very small part of each sponson touching the water, while the transom will be lifted out of the water by prop. Because of this, the hull has very little drag. |
Pictures courtesy of by Nate West! |
Riggers If you want to run the fastest you can on flat water , there is no substitute for a Rigger! With straightaway speeds faster then any of the other hull designs, along with razor sharp handling makes this, the hull to beat in racing. Set up is the hardest of all the hulls, with the exception of the canard style hull. As you can see in the left picture, on a well setup rigger not much touches the water! One of the downfalls to the rigger style of hull is that they like to run at full speed. The picture on the right is a rigger at low speed, but once on plane they practically fly!
Picture courtesy of Gregor Vida |
Picture courtesy of Bryan of |
Canards A Canard looks like a backwards Rigger. While a well setup Canard is slower in the straights then a Rigger, it will have faster cornering speeds. This type of hull is only for the seasoned Rc boating enthusiast. Not many people are able to set these up successfully. |
- Items by Manufacturer
- All Products
- About Us
- Store search
- Terms & Conditions
- Tips on Surfing this Site
- OSE Sponsorships
- Sitemap
