OSE Flex Cable Assembly for the ProBoat Impulse 31 V3. Upgraded .150" Cable with 3/16" prop shaft. This is cut and ready to install in your boat. This upgraded cable is a higher quality with thicker wire strands and is better aligned to the prop shaft than the stock unit. The prop shaft is only 2.25" long, which reduces resistance and allows more strut adjustment. This will help reduce vibrations, which will help reduce strut bearing wear. Just install it and go! This is for a 4s setup. For a 6s lipo, use the HD cable.
No soldering or cutting is required! Benefits over stock cable: Thicker gauge flex cable windings. Soldered end for both added grip within the coupler and to help with unwinding the cable end.2.25" (57mm) Prop shaft for reduced drag.
This can also be used in any other boat requiring a .150 cable that measures approx 215mm (+/-2mm) from tip to tip. Includes: Teflon Liner, .150 cable with 3/16" prop shaft and attached drive dog and streamlined bullet nut.
