OSE heavy duty flex cable assembly for ProBoat Impulse V3. This is for customers with a heavily modified ProBoat Impulse V3 boats that are using 4074 and 4082 motors. This cable is made with thicker gauge .187" Cable assembled to a 3/16"(.187) prop shaft and bullet nut. The cable we use is over 20% thicker than the stock ProBoat cable. This is cut and ready to install in your boat (requires ose-81518).
No soldering or cutting required!
NOTE: This will NOT fit a Stock Impulse V3 without the following additions. Requires: ose-81518 5mm to .187 Coupler and removal of stock proboat Teflon liner.
