OSE TFL Ariane heavy duty flex cable assembly. This is for customers using 4s-6s Lipo power or a modified TFL Ariane boat. This cable is made with a thicker gauge .187" Cable assembled to a 3/16"(.187) prop shaft and bullet nut. The cable we use is over 15% thicker than the stock TFL 4mm cable. This is cut and ready to install in your boat (requires ose-81518).
No soldering or cutting is required!
NOTE: This will NOT fit a Stock TFL Ariane without the following additions. Requires: ose-81518 5mm to .187 Coupler and removal of stock Teflon liner. Includes:OSE-cable-1191 oct-oc6pnmm Bullet nutose-80248 Tapered drive dog
