Linkage Rod Connector for 2.5mm rod. See picture 2 for measurements.
For 2.5mm push rods. Will accept linkage rods up-to 2.5mm. The linkage connection is secured with 4mm grub screw and held to the rudder with a nylon insert lock nut. Body of connector made of stainless steel. Specs: (1) Stainless Connector per pack (1) 4mm Long, grub screw for holding rod in place. (1) 3mm nylon insert lock nut.
