OSE motor mount for 56mm diameter motors. CNC aluminum rings with carbon fiber mounting rails. Mounting rings can slide forwards and backwards. This is a very versatile mounting with the mounting holes in the rails. The center aluminum rings measure approx 3.94" (100mm)Comes with mount only. Motor and water jacket only in pictures for display purposes. Note: -This will only work with motors in a diameter of 56.00 to 56.30-We found that the top esc plate can be mounted with either 2 screws or 4 screws. -Works with water jacket with maximum length of 50mm long.
Measures:Approx. 110mm (4.33") wide x 185mm (7.25") long
