Adjustable motor mount for 28mm motors
Designed to fit Vee bottom hulls. Now comes with black fiberglass stands that have holes drilled in the bottom to allow epoxy to flow in them resulting in a superior bond. Angle is adjustable to allow straight alignment with propeller cable. The anodized aluminum mounting plate is water cooled for added insurance against over heating. This can come in handy with both inrunner and outrunner style brushless motors. Its especially useful in outrunner motors, that do not have water cooling fitted to the motor. Applications: Leo 2845, 2850, 2860, and 380 sized brushed motors.Specs:Fits most 28mm Diameter motors that use a 16mm to 19mm mounting hole spacing, as long as the motor mounting screw is not larger than 3mm.Center Metal Section Width: 44mm (Not including the stands)Fiberglass Stand Width: 2mm**Requires you to provide motor mounting screws.**
