Octura .150 flex cable with 3/16" prop shaft, drive dog, basic nut and teflon liner. Flex Cable is approx 22" Long. Un-assembled, requires attaching the shaft to the cable with solder or glue. We also offer these assembled in the Flex cable assemblies category, click here.
Includes: (1) Propeller Shaft oct-oc6150ps 2 1/4" (57mm) (1) Drive Dog pn# oc6dmm (1) Thin Prop Nut: pn# oct-n1032 (1) .150 Flex Cable approx 22" long (1) .150 Teflon Tubing approx 22" Long : pn# oct-150T-24
Requires: 7/32 OD K&S brass tubing pn# 8130 for stuffing tube when used with the NO Teflon liner. 1/4 OD K&S brass tubing pn# 8131 for stuffing tube when used with the included Teflon liner. Solder or glue the flex cable into the propeller shaft. Set the drive dog and cut the flex to your desired length.
