Leopard 4092 brushless motor. Includes water Jacket with Leopard Motor Purchase! 40mm Diameter by 92mm Long Brushless Motor by Leopard Power. Hand wound for high efficiency of up to 90%. Comes with high-quality bearings and neodymium magnets for high power. Includes endbells that are assembled with screws for both strength and ease of maintenance. We offer this in 7 versions. 700 Kv/rpm per volt 4Y 930 Kv/rpm per volt 3Y 1050 Kv/rpm per volt 5D 1390 Kv/rpm per volt 2Y 1480 Kv/rpm per volt 3.5D 1730 Kv/rpm per volt 3D 2080 Kv/rpm per volt 2.5D Specs: Magnets: neodymium Watts: 2600 with Over 4200 Burst. Poles: 4 Motor Shaft: 5mm with a flat spot Can Measures: 40mm diameter x 92mm long Weight: 492 Grams Mounting screw diameter required: 3mm Bearing size: 5mm wide x 16mm od x 5mm id Mounting Holes 25mm apart for use with most 540 mounts.Includes Leopard 6.0mm male bullet plugs soldered to the motor and a matching set for your ESC connection.
OSE Suggests 20,000-35,000 total rpm for boats. We suggest most Fast Electric Boaters should run in the 25,000RPM range for sport boating or the 30,000RPM Range for racing. These are only guidelines, we suggest if you don't know how to pick the correct motor, please consult us first or other members of the rc fast electric boating community, either at a local club or on our OSE Forums. If you are using the OSE-80600 or 80610 mounts, we suggest the leo-4050 water jacket. For mounts with no rear clamp, you can use the longer leo-4076 Water jacket.
