Etti adjustable motor mount for 380 inrunner or outrunner motors with 16mm motor screw spacing. Blue anodized center section with water cooling and black fiberglass stands.
Requires: Motor screws. Mounting of the unit in the hull. And gluing of the water inlet and outlet in the desired position. Center metal section measures 36mm wide (without stands)
