Etti adjustable motor mount for 380 to 480 sized Motors with 19mm motor mounting holes! Fully adjustable in height and motor shaft angle, makes this one of the easiest mounts to align perfectly with your drive shaft. The mounting plate can be flipped over so it can be mounted deep into a monos deep vee or on a flat surface like a catamaran or hydro. Motor plate is anodized blue, Brackets are black fiberglass. Applications: Fits 380 to 480 sized Motors with 19mm motor mounting holes! Center section measures 48mm wide (not including the stands).
